String from device
Please help to compare a line, It is necessary to execute action if in line from the device is (60)!!!
WHAT IS NOT CORRECT?
DEFINE_VARIBLE
SRING_FROM_DEVICE[50]
V INTEGER
DEFINE_EVENT
DATA_EVENT[DV_LIGHTS]
STRING:
SRING_FROM_DEVICE=DATA.TEXT
LIGTS_CONTROL(SRING_FROM_DEVICE)
DEFINE_FUNCTION LIGHTS_CONTROL(STRING_FROM_DEVICE)
V=FIND_STRING(STRING_FROM_DEVICE, '60' ,1)
IF(V=1)
ON[TP,100]
ELSE
OFF[TP,100]
ON[TP,100]
    Try this:
    DEFINE_VARIBLE
    char SRING_FROM_DEVICE[50]
    INTEGER v
    DEFINE_EVENT
    STRING:
    LIGHTS_CONTROL(SRING_FROM_DEVICE)
    DEFINE_FUNCTION LIGHTS_CONTROL(char STRING_FROM_DEVICE[])
    if(FIND_STRING(STRING_FROM_DEVICE, '60' ,1))
    ON[TP,100]
    ELSE
    OFF[TP,100]
    See if that works better.
  • LehaLeha Posts: 37
    Spire_Jeff wrote: »
    Try this:
    DEFINE_VARIBLE
    INTEGER v
    DEFINE_EVENT
    STRING:
    ON[TP,100]
    ELSE
    OFF[TP,100]
    Whether it will work if a line from the device (30, statcx60,32)?
    Leha wrote: »
    Is (30, statcx60,32) an ASCII string, or is it a mix of ASCII and decimal/hex code? If the string is literally "'(30, statcx60,32)'", the find_string should be true.
    Spire_Jeff wrote: »
    I am not assured that it is a line! And how to learn what is it?
    There are a couple of ways to see what it is. You could connect your computer to the device directly and monitor the incoming strings using hyperterminal. You could use the device notifications and monitor strings coming into the processor. You could use send_string 0,"data.text" and watch diagnostics.
    Pick the one that works for you, but understand that some of the methods that use the processor could be cut off if a $00 code comes in.
    P.S.
    You should also be looking at a manual that defines the protocol being used. Without this, it can be done, but it is fairly difficult and very prone to unexpected strings not being interpreted.
    Spire_Jeff wrote: »
    P.S.
    I used Netlinkdiagnostic, comes string from device [80,36, statcp, 60,30]
    I think that is showing ASCII, so the code I posted should work. Is it not working properly?
    P.S.
    In the function, make sure you remove the last ON[TP,100] statement as I did. The statement gets executed regardless of the condition.
    Spire_Jeff wrote: »
    P.S.
    Works only when is not present 60 in line.
    I suppose I should ask you want you want the code to do? If you simply want everything to be exactly opposite, you could just switch the code in the IF section with the code in the ELSE section.
    If you could describe what you want to happen in a little more detail, I might be able to suggest a change to the code.
    new
    On a picture the answer from the device. The program does not work, where an error?
    PROGRAM_NAME='AMX'
    DEFINE_DEVICE
    MIO_R4 = 128:1:0
    LIGHT = 5001:5:0
    DEFINE_VARIABLE
    VOLATILE CHAR STRING_FROM_DEVICES[50]
    DEFINE_EVENT
    DATA_EVENT [LIGHT]
    ONLINE:
    SEND_COMMAND LIGHT,"'SET BAUD 9600,N,8,1 485 Disable'"
    DATA_EVENT [LIGHT]
    STRING:
    STRING_FROM_DEVICES = DATA.TEXT
    LIGHT_CONTROL(STRING_FROM_DEVICES)
    DEFINE_FUNCTION LIGHT_CONTROL (CHAR STRING_FROM_DEVICES[50])
    IF(FIND_STRING(STRING_FROM_DEVICES[50],'60',1))
    ON[dvTP6,3000]
    else
    Off[dvTP6,3000]
  • HedbergHedberg Posts: 671
    I don't now if this is the only problem with your code or not, but look at this line:
    You are trying to perform the find_string function which requires a string as the argument.
    is a single character. In my opinion, this shouldn't even compile, but apparently it does.
    If you want to evaluate a string with this function it should be:
    FIND_STRING(STRING_FROM_DEVICES,'60',1)
    Also, you are using the same variable name (STRING_FROM_DEVICES) for both a global variable and a variable local to your function. The way that you have it will probably work as intended, but it might be confusing.
    Hedberg wrote: »
    If to write so should work?
    FIND_STRING (STRING_FROM_DEVICES, ' 60 ', 1)
  • That looks like it should work. the STRING_FROM_DEVICES is a CHAR variable of 50 characters, containing the string. STRING_FROM_DEVICES [50] as part of a function or argument is the 50th character in the string.
    example
    CHAR STRING_FROM_DEVICES [50] = " '12345678901234567890123456789012345678901234567890' "
    SEND_STRING 0, " 'sending ', STRING_FROM_DEVICES, $0D "
    will return "sending 12345678901234567890123456789012345678901234567890$0D"
    whereas
    SEND_STRING 0, " 'sending ', STRING_FROM_DEVICES [50], $0D "
    will return " sending 0$0d "
