Axcent3 RS232 at 115200 baud
Hello guys,
Has anybody managed to set any of the 6 RS-232 ports of an Axcent3 Pro at 115200 baud? The AMX documentation says those 6 serial ports can be run at that speed but, so far, I haven?t been successful.
Thanks!
Regards,
Jordi
  • Hello guys,
    Thanks!
    Regards,
    Jordi
    Can't remember if I ever ran an Axcent3 port that fast, but you will probably want to keep the cable run as short as possible and use CTS/RTS handshaking.
    Yes, but I beleive that the send_command value was 115000 or 115,000.
  • 115k is the trick!!!
    Hi again,
    I finally found the method to set the Axcent3 DB9 serial ports at 115200.
    SEND_COMMAND RS232_1, 'SET BAUD 115K,N,8,1'
    Thank you for your help!
    Regards,
    Jordi
