Home AMX Control Products
How i can make G3 WEBCONTROL
i have seen some thread. Peoples are working with g3 web control. How can stat it.
    I would recommend you don't. It's flaky, limited, and unsupported ... a bad combination. Only do it if you absolutely must.
  • ryanwwryanww Posts: 196
    I am pretty sure its broken with the latest version of java. I just tried this a couple days ago and I couldn't get it to work. Either way, you can try. In tpd3, you go to file, save as html. Select Netlinx, your start panel address and save location. Hit convert. When complete, you can click the ftp transfer to have it throw the folder on the root level of your master, then when you go to the root web page of your master it will show up in the list.
    Ryan
