Has anyone programmed AMX Novarra keypad, I am controlling a Sharp 65inch LCD which has a command for volume VOLM(0-60). How will be the volume up and volume down incorporated with this command.
You will need volume up/down commands to implement this, discrete volume control programming is, as far as i know, not supported in the novara keypads.
thanks for the reply
so in this case I would just call a presets on volume... (eg 10%, 50%, 100%)
hi there, has any one tried the novarra in windows 7 does it work....
It doesn't. at least not on the 64-bit version. I had to use windows xp to program them.
