SEND_STRING problem
I am trying to control device, and I have some Windows program that is working ok.
I use Serial port monitor to see traffic, and try to copy Tx to NetLinx.
It look like this
command look like this
but I dont have respone.
Port is set ok, any other ideas ?
It look like this
02 0A 00 01 01 01 10 65 86 03
SEND_STRING dvPortovi,"$02,$0A,$00,$01,$01,$01,$10,$65,$86,$03"
Does the string need an <LF> or <CR> at the end? Most terminal programs will add this for you when you hit the Return key.
Try adding a $0d or $0d,$0a at the end.
If it isn't a CR issue, your string looks just fine. It could be anything from a device issue to a bad wire though, there just isn't enough to go by.
