Can you fast forward a timeline?
travis
Say you have a timeline with some long events and you want to make a button that skips the timeline to the next event and the timeline keeps going. I'm going to go try it out right now.
edit: ok here it is, mostly.
LONG TimingArray[] = { 10000, 10001, 10002, 10003 } TIMELINE_CREATE(SHOW_TIMELINE,DayTimingArray,MAX_LENGTH_ARRAY(DayTimingArray),TIMELINE_RELATIVE,TIMELINE_REPEAT) DEFINE_FUNCTION LONG get_absolute_time(LONG timeline_array[], INTEGER sequence) { LOCAL_VAR INTEGER I; LOCAL_VAR LONG absolute_time absolute_time = 0; FOR(i=1;i<=sequence+1;i++) { absolute_time = absolute_time + timeline_array[i]; } RETURN absolute_time; }
TIMELINE_EVENT[SHOW_TIMELINE] { TIMELINE_SEQUENCE = TIMELINE.SEQUENCE SEND_STRING 0, "'TIMELINE.SEQUENCE', ITOA(TIMELINE_SEQUENCE)" } CHANNEL_EVENT[dvTest, 1] { ON: { LONG XYZZ XYZZ = get_absolute_time(DayTimingArray, TIMELINE_SEQUENCE); SEND_STRING 0, "'TIMELINE.SEQUENCE', ITOA(TIMELINE_SEQUENCE)" SEND_STRING 0, "'current timeline time: ',ITOA(TIMELINE_GET(SHOW_TIMELINE))" TIMELINE_SET(SHOW_TIMELINE, XYZZ ) SEND_STRING 0, "'setting timeline to: ', ITOA(XYZZ)" SEND_STRING 0, "'current timeline time: ',ITOA(TIMELINE_GET(SHOW_TIMELINE))" } }
The only hassle is using a relative timeline because the timeline still counts absolute, hence the function to add all the times in the array up to the current sequence id/index.
PS. isn't here already TIMELINE_RESET?
I think that's what I tried first. I hope I did and I didn't write all those loops for nothing.
