Home AMXForums Archive Threads Residential Forum
Samsung LCD PC input
I am figuring at this point there isn't such a thing, but does anyone have the IR code to get a Samsung LCD to switch to its PC mode that doesn't toggle? All the ones I have tried switch to PC but sending the same command again makes it toggle back to the last used input. I can't see where that would ever be useful but that's Samsung.
  • rcainrcain Posts: 11
    try these. I know the first one works for the Plasmas as I used it today with an RTI system.
    PC 1
    0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0689
    PC 2
    0000 006D 0000 0022 00AC 00AB 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0689
    rcain wrote: »
    PC 1
    PC 2
    Thanks, those work but toggle unfortunately. I am thinking that there is no Samsung IR that doesn't toggle PC/last input :( I came up with a workaround but geez!
    sorry about that. I never checked to see if it was a toggle code. I had that problem with HDMI 1 until I found the code set with the above PC codes.
