NI-4100 slow startup
in AMX Hardware
Hi all,
I have a problem with a NI-4100...
After loading it with the latest firmware (3.41.422) I couldn't connect to it anymore.
I waited some time, and after a while I could connect again (few!)
Thought it was something related to the firmware update, but it keeps happening.
If I open the log-file I see an entry that says something like: "Timed out waiting for Duet"
After that, all my devices are online, and I can open up a debug window to watch variables.
I think the system is working now, but I get a bad feeling about this.
Anyone has had this before?
P.S.
I have also tried to start with PRD dipswitch on, the master is not on DHCP...
P.S.
from terminal/telnet: clean disk -f
reboot
load firmware again
boot with no program
load program, reboot
You may also check the Duet mem. 8M should be good.
Thanks for the replies! I ordered a new compact flash card, just to be sure.
I say this because I had a perfectly running system until I upgraded the FW on the NI and then the Duet modules would no longer run until I updated the SNAPI router.
Download the firmware again, download your program again. If everything is running ok and you want, you can do the reset factory command.
I used clean disk -f and reloaded the firmware, then reloaded the program and all is wel now.
Thanks!
I even swapped out the CF card with a brand new one, and still have the same problem, but also other problems emerge.
Suddenly relays/io stopped working, after a reboot all is well again.
Sending compiled source code sometimes fails and forces me to reboot the master by hand (power plug)
I even tried sending another piece of software which is working on another 4100 and that didn't work either.
Also I tried testing my current software on another frame (NI-3100) and it worked flawless...
Sending this NI-4100 in for Advanced Replacement...
I don't know how much time your Ni-4100 is in your stock, but you also tried to download the device firmware?
http://www.amx.com/techcenter/downloadConfirm.asp?fn=/assets/firmwareFiles/SW2105_04C_NIx100_Device_v1_13_7.kit
it already had 1.13.7, it's a brand new device (at least, brand new from AMX, i don't know how long AMX has stuff in their stock)
