Denon avr-3310CI power on.
I'm using the avr 4308 module to control the 3310 since there isn't a module available for the 3310 yet. Most things worked fine, except to select the SAT input, and a couple others, I needed to use passthru due to a protocol change. To power the unit off, I just pulse channel 28 of the virtual, which works fine, but pulsing channel 27 does not work for power on. Any thoughts? I haven't looked for a protocol change on the power on command yet, but didn't know if anyone had any thoughts. Thanks.
  • Use passthru and send the following string
    SEND_STRING dvDenon, "'PWON',13"
