Help making a Dialer?
I am making a telephone interface and would like to display the numbers as they are dialed. I am having trouble figuring out how to add each dialed digit to the string that is sent to the text area, and also how to remove a digit via a delete button. Can someone point me in the right direction?
thanks.
thanks.
You can look up length_string on AMX-PI to learn how to shorten the string if the user backspaces.
You can also consider using the system keypad. The text area on the system keypad will show the string as its entered, and handle the backspace for you. When the user pushes "dial" or however you mark the escape button, the whole string will be sent to the master as a string data_event.
--John
The dialer is working now. Thanks for your help. The working code is below, FYI.
///TC Dialer Btn Numbers
BUTTON_EVENT[dvTP_TC,Btn0]
BUTTON_EVENT[dvTP_TC,Btn1]
BUTTON_EVENT[dvTP_TC,Btn2]
BUTTON_EVENT[dvTP_TC,Btn3]
BUTTON_EVENT[dvTP_TC,Btn4]
BUTTON_EVENT[dvTP_TC,Btn5]
BUTTON_EVENT[dvTP_TC,Btn6]
BUTTON_EVENT[dvTP_TC,Btn7]
BUTTON_EVENT[dvTP_TC,Btn8]
BUTTON_EVENT[dvTP_TC,Btn9]
PUSH:
NumPress = itoa(button.input.channel-10)
NumDial = "NumDial,NumPress"
SEND_COMMAND dvTp_TC,"'^txt-31,1&2,',NumDial"
BUTTON_EVENT[dvTp_TC,BtnBackSpc] ///backspace
PUSH:
STACK_VAR NumDialLength
NumDialLength = LENGTH_STRING(NumDial)
NumDialLength = (NumDialLength-1)
SET_LENGTH_STRING(NumDial,NumDialLength)
BUTTON_EVENT[dvTp_TC,BtnClear] /// clear dialer
PUSH:
SET_LENGTH_STRING(NumDial,0)
PUSH:
set_length_string(NumDial,length_string(NumDial)-1) //remove digit
