NEC Projectors and RS232
I have a new projector which I'm installing. It's a NEC NP500WSG. I used a NEC MT1065 before. From what I can tell the commands are exactly the same as before more or less - however when I send out to the project any command - it just gets reflected back ? See below - any ideas ?
Line 780 (12:18:02):: String To [1:1:1]-[$00$81$00$00$00$81]
Line 781 (12:18:02):: String From [1:1:1]-[$00$81$00$00$00$81]
Ed
  • ColinColin Posts: 51
    Check your wiring 1st
    I'd check the wiring first to ensure there isn't a short between pins 2 & 3
    On the NP Series I use
    "02,$00,$00,$00,$00,$02" to turn the NEC on
    "$02,$01,$00,$00,$00,$03" to turn it off
    Hope this helps
