IR fail to Toshiba 52WV645U
I'm just doing IR control for an LCD TV; I capture the IR codes from the remote, map, upload to controller. I'm getting the pulses I expect from the emitter, but the TV won't respond. I've tried CTON/CTOF timings everywhere from 1-10. I've re-captured the IR from the remote, re-did everything else, still no love.
Not sure I've ever failed so miserably at something that should have been so simple. Any ideas out there?
Have you tried holding the emitter 1ft from the screen and see if if will respond?
It will take me just a bit to get the IR codes out.
Also as mentioned in another current post ensure you have these in your IR port DATA_EVENT ONLINE handler: Although they are the defaults things aren't often what they should be.
Have you checked with a camera phone that the emitters are flashing?
this might be outside odds...
I ran into an issue recently with my IR stuff. I would capture a file and it would just flat not work. I'd see IR flashes on my cell phone camera and all that. It would just not work.
then I noticed that susequent IR captures were not working as well. My IRIS seemed to be working just fine, but anything it capured wasn't working.
I sent it in and they recalibrated it. Now it works fine.
Have you tried to capture other working codes on another already working IR rig? Perhaps the IRIS you're using is not functioning properly.
Just a thought...
Attached is the IR file I captured. The only IR code I actually need is Power, but I've tried 5 different codes so far and the TV won't pick up any of them.
A failure in the IRIS box is a fair guess; I don't have another one to try right now. I'll poke around on that some more.
Here's the code I'm using:
Thanks for the help everyone!
Power On:
Power Off:
I swapped the Xantech emitter for a very old AMX one and that fixed issue.
I know the AMX emitters are pricey but they seemed to work better than the Xantech ones.
An AMX IR emitter works fine. None of the Xantech "blinker" emitters do. This is the first time I've ever run across a difference in functionality between the two, besides the visible light in the Xantech ones. Fascinating.
I've got a whole drawer full of the AMX emitters because we always just use the Xantech ones instead. The visible blink is a godsend during installation and troubleshooting. Or, used to be, more like.
Thanks!
Look at that, I'm the winner and I still don't get a prize.
Glad I could help. Hopefully no one else on these forums will have to spend the time that it took me to figure this one out. A dealer and I were beating ours heads against the wall for several hours trying get the Xantech to work.
