Timeline Questions
Quick question on timelines...is the following code legal and will work?
It didn't seem to work in testing, and I was curious if it is even legal to do it this way.
DEFINE_CONSTANT //Timeline Constants TL_SOURCE_SELECT[]= {1,2,3} //snip button_event [vdvTPSwitcher, nSwitcherOutputs] { push: { stack_var integer nOutput stack_var integer nButton stack_var integer nTP stack_var dev dvTP nOutput = get_last(nSwitcherOutputs) nButton = button.input.channel nTP = get_last(vdvTPSwitcher) dvTP= button.input.device if(timeline_active(TL_SOURCE_SELECT[nTP])) timeline_kill(TL_SOURCE_SELECT[nTP]) if(iSelectedInput > 0) { if(length_string(CSelectedOutput) = 0) CSelectedOutput = "itoa(nSwtOutputMap[nOutput])" else CSelectedOutput = "CSelectedOutput,itoa(nSwtOutputMap[nOutput])" on[dvTP,nButton] } else { SourceFeedback(nSwtOutputMap[nOutput],dvtp) on[dvTP,nButton] } timeline_create(TL_SOURCE_SELECT[nTP],TL_OUTPUT_TIMES,1,TIMELINE_ABSOLUTE,TIMELINE_ONCE) } } DEFINE_EVENT //Timeline Events timeline_event[TL_SOURCE_SELECT] { //do something }
I don't beleive you can use an array to address Timelines. (at least not right now. It's been discussed, and cussed...)
You'll have to stack them instead.
so,
