AMX and Global Cache: Connection drop
Hi everyone,
I'm working on a project with several global cache and after a short time (2-3 min) the connections between the Master and the GC are closed, any idea?
For the moment I'm just re-opening the connection after each deconnection, which is not a really good solution.
I'm opening two connections to the GC, one on the port 4998 to user relay and the other one on the port 4999 to use the first RS-232 port for the projector.
I've open the two ports directly from my laptop to test the relay and send some commands to the projector and I didn't loose the connection, is there any timeout I need to configure?
Here is my code for one GC:
FYI: I am using the same network of the company but on a separate VLAN, I didn't create it myself so I don't know the settings
Thanks in advance for your help,
Seb
dvGC_Classroom_1 = 0:5:0
dvProj_Classroom_1 = 0:13:0
DEFINE_START
IP_CLIENT_OPEN(dvGC_Classroom_1.PORT,'163.183.245.10',4998,TCP_IP)
IP_CLIENT_OPEN(dvProj_Classroom_1.PORT,'163.183.245.10',4999,TCP_IP)
DATA_EVENT[dvGC_Classroom_1]
ONLINE:
SEND_STRING 0,"'CONNEX OK AU GC CLASSROOM 1'"
OFFLINE:
SEND_STRING 0,"'********************* GC CLASSROOM 1 OFFLINE *******************************'"
WAIT 2
DATA_EVENT[dvProj_Classroom_1]
ONLINE:
SEND_STRING 0,"'CONNEX OK AU GC PROJO CLASSROOM 1'"
OFFLINE:
SEND_STRING 0,"'**************** GC PROJO CLASSROOM 1 OFFLINE**********************'"
WAIT 2
Seb
In any event, you may be able to keep the connections open by querying the GC and/or projector for some status every 45 to 60 seconds.
It seems to be the same problem I'm facing, I guess that the GC is not responding to the keep alive. I'll do some testing with wireshark but the best solution will probably be to keep alive the connection myself.
Thanks again,
Seb
