Lifesize IP Communication
Hi All
I`ve just recently come off the P2 course and i`m challenged with connecting to the Lifesize VC system via IP.
I can make the initial connection to the unit ( which i`ve flagged using a channel so I know its online ), the only problem is that you need to send the username ( auto ) and password ( lifesize ) to keep the connection up? I can Telnet into the system via Putty and it works fine, I just cant seem to establish a connection with the system and keep it 'up'!
I have no problem controlling the system via RS-232, its just the IP which is proving awkward for me.
I`ve tried sending the username and password straight after the connection has been made. I`ve tried sending it in intervals ( with putty it takes a couple of seconds once you have typed the username in to be able to put the password in ).
I`m just wondering if anybody else has had the same problems and whether anybody will be able to point me in the right direction
Many Thanks
Dave
  • Dave,
    Here is how it was done in a system that I worked on. I didn't write the system but got called in to make some adjustments.
    ONLINE:{
    WAIT 20
    SEND_STRING dvVTC,"'auto',13,10"
    WAIT 20
    SEND_STRING dvVTC,"'lifesize',13,10"
    OFFLINE:{
    WAIT 300
    IP_CLIENT_OPEN(dvVTC.PORT,'192.168.70.25',23,1)
  • davecdavec Posts: 21
    Danny,
    Thanks for that. I wasn't giving it enough time between sending the username and password. I was only giving it 15!
    God damn these simple problems! All comes with experience though!
    Dave
