Changes at AMX US & now UK
After seeing the sudden changes in the US before christmas, things are also changing in the UK if not in Europe in general... the main UK AMX distributor, RGB has dropped AMX with immediate effect.
(not having any inside info, but based on similar events in the past, this would probably have been in response to being told that AMX was going to move towards a direct operation & RGB's response was to cut ties immediately as with ******** and Extron before!)
As AMX Europe has not released any new information on the new sales channel, this all appears to be fairly hasty (hence the above thoughts), but in the meantime, please AMX, get a message out there - the only sales contact you have listed for UK on amx.com is the European MD!!
I can only hope that there are some killer new products on the horizon, combined with a major marketing push to warrant the narrowing of the dealer base that these moves appear to be causing...
  • iainshawiainshaw Posts: 133
    Bullseye
    It would probably help if someone in the European organisation commented on Bullseye. What is it? How does it affect us? Are you listening at all?
