Multi-Line Commenting out of code - Easy Question
I learned this in P1, but I've forgotten: what are the keystrokes used to comment out multiple lines of code? I thought it was an ALT+ command, but I can't figure it out!
  • jjamesjjames Posts: 2,908
    Setup Dependent?
    On my machine I've been using F2 for a while, but I don't know if that's the default.
    Typically though when I want to comment out a block of code, I use /* and */ to comment out a block.
    DEFINE_FUNCTION INTEGER	fnGET_PANEL
    (INTEGER nROOM)
    	STACK_VAR INTEGER nCOUNTER;
    	FOR(nCOUNTER = 1;nCOUNTER <= LENGTH_ARRAY(nPNL_AV); nCOUNTER++)
    		IF(nROOM == nPNL_AV[nCOUNTER])
    			RETURN nCOUNTER;
    			BREAK;
  • HedbergHedberg Posts: 671
    It's an edit menu item -block comment and uncomment. Keystrokes alt+E, then o. Or, you can assign any hotkey sequence you desire. I like alt+/
  • vegastechvegastech Posts: 369
    Nice!
    Thanks! Now that I know where to look, the keystroke combo Ctrl+B does it. I don't care what anyone else says about you guys, you're Awesome! ;-)
  • the8thstthe8thst Posts: 470
    You can also use wrap the code like so:
    (INTEGER nROOM)
    			RETURN nCOUNTER;
    			BREAK;
    Old Dog - New Tricks
    I've been doing this a long time and never knew this was available. Ha!
    I just did the old
    a whole bunch of code
    thiing myself.
    I didn't know about the /* ... */ thing either. I just highlight the block and hit the comment button on the tool bar ... it pre-pends a // to every line, and removes them just as readily.
    DHawthorne wrote: »
    The *only* thing I don't care for about that way of it is if there's already comments a the line, it can get a finicky (at least it has for me), which is why I've always done the /* */ (and in the past (* *) ).
    As always - a million ways to skin the cat. ;)
