Exporting WS
I have taken some time to create a workspace for all my code used across campus. When I access them in the ws they work great. The problem is when I attempt to export the file I get a list of code that wasn't transfered because it was not found. How come everything compiles and works fine but I can't export without errors. Has anuone else noticed this?
    I have exported workspace occasionally and I have not had any problems. Did you try checking different options in the dialog? Did it generate anything more specific in the error message?
    Check each file in the WS; I've been yatching about this since the last version of NS came out. It corrupts the workspace by stripping subfolder information. It doesn't do it with new workspaces, only with workspaces made in previous versions. In most cases, you can fix it by right-clicking the entry and editing the properties. It still won't find the modules though, unless they are actually in the project folder. Oddly enough, it finds them fine if it's a new workspace, it only has that issue with older ones.
  • I've talked to tech support and the engineers are looking into my code right now. I was able to export other WS of mine but this one is an odd ball. I'll post AMX findings.
