time not right
Thomas Hayes
in AMX Hardware
Hi All
I have an NI-2100 that will not maintain its time, I have even added it to my RMS and this unit lose's hours everyday. I could understand if the battery was dead but the power is always on and the unit still lags time 10-20 minutes / hr. Sounds like a bad internal clock to me. Has anyone else had this type of issue?
Not on a Netlinx master but once on an older Macintosh with the old on-the-board clock/battery chip. In that case it ran really fast. I attributed it to a bad Heisenberg compensators not protecting it from the effects of uncertainty.
--John
Or sometimes the flux capacitors just go bad
--John
Can you call tech support and get this RMA'd? Let them know to send it to Rick in engineering. I'd like to understand what the issue is with this unit and make sure it isn't something more systemic.
P.S. my bunny is happy he doesn't have to be dyed pink.
The solution is to either a) replace the yellow snap-hat battery or b) switch the master to use Network time if the master has connectivity to the internet. Under Network time, the master will periodically connect to a Network time server on the internet and set it's time appropriately.
