Daikin Intelligent Touch Controller?
So I've read every thread and researched all of the AMX based solutions for integrating with a Daikin system. Then I found out that the HVAC contractor is using a Daikin Intelligent Touch Controller (http://www.daikin.com/global_ac/products/network_solution/i_touch/index.html) and is only granting me access to tie into that.
After digging a little deeper I discover why the contractor is telling us to integrate this way. C*tron has a module that ties into the Daikin ITC over IP directly, no external hardware needed. I like this approach better then the others discussed in the previous threads, but haven't heard anyone mention anything about it. Does anyone have any experience with it?
There is a massive document explaining the IP protocol, which I have as the integrator has signed Daikin's NDA. It isn't easy to use though as it is designed for use within a web browser. The ITC defaults to 256 units and as a result spits out data for all of them every time, however I'm going to give it a go as I don't have many other options. There is a RS-232 port on it as well as LAN, but I don't have any info on how to use this, which is a shame.
Anyone else?
Simon
If you need an easy RS232 interface for integration of the AMX with several VRV/VRF systems (not just Daikin, but also Hitachi, Toshiba, Sanyo, Mitsubishi electric) you might google for third party devices, like CoolMaster for example.
It is very easy to integrate, and it is Plug&Play to the air conditioning system...
I've just come across one in a project, I've worked out most of the conversions used to format the various data, but when I send a HTTP POST command to the unit, all I receive is a "HTTP Bad Request" in response.
Any help would be appreciated
The protocol works fine, although converting the temperature back and forth is quite complicated as you have probably noticed. It sounds to me like the software on the iTC needs updating - the webserver portion does not come as standard and needs adding by the Daikin supplier, and you will get nothing back from the iTC until this has been implemented. Be warned - it's not a cheap upgrade.......
Let me know how you get on as I have a couple of projects using the iTC on 6/7 zones and it seems pretty robust once it's all talking OK.
Simon
Just found out the same thing from a Daikin engineer this morning. Hopefully the software upgrade cost can get soaked up somewhere else in our budget!
Yeah, the conversions for float set point are pretty tough! Luckily I'd just recently created a driver for a HVAC system called Cylon, which uses a lot of the same conversions (especially IEEE754). Here's a link to an amxForum thread which gave me much of the code I needed (many thanks to user: JWeather):
http://www.amxforums.com/showthread.php?3423-Ieee-754&highlight=ieee
Could you please share the code?
New drriver for CoolMaster is being prepared (or already released) in AMX database.
For example, the one I just wrote for controlling Mitsubishi doesn't accept the option to switch temp. scales the F - it only uses C which made generating the UI and accepting user changes in F a little more "fun"
The driver is released and can be found on AMX drivers' database.
Farenheit support for Mitsubishi is already avalwable in the newer firmware version...
