Dev Array In Call
                    Could someone help me out with the following.
I have an array of panels
DEV dvTP[]={dvTP1_1,dvTP2_1,dvTP3_1,dvTP4_1,dvTP5_1}
I can do this to send a command to all panels
SEND_COMMAND dvTP,"'@PPX'" //CLOSE ALL POPUPS
I have a call like this
DEFINE_CALL 'closepps' (DEV PANEL)
SEND_COMMAND PANEL,"'@PPX'" //CLOSE ALL POPUPS
But cannot do this - call 'closepps' (dvTP)
I have probably missed something as i normally do.
Michael
Michael
But anyway - in your call parameter, it's set for only a single device. It should be:
DEFINE_CALL 'closepps' (DEV PANEL[MAX_PANELS])
Where MAX_PANELS would (obviously) be the maximum number of panels you have in the system. I don't know if defining the bounds of the array is necessary for a call / function, but it doesn't hurt I don't think.
There will be more than one line of code, that was just an example, i will give your suggestion a try now thanks for the quick response.
A few complier errors in the call now relation to a dimension mismatch. I will keep pluggin on.
I have tried empty [] in the call
DEFINE_CALL 'CLOSEPPS' (DEV PANEL[])
But it throws these errors
Dimension mismatch: [1] vs. [0]
Type mismatch in call for parameter [PANEL]
I will knock up a hack to get round it and pick it back up Monday it's friday and nearly home time.
I would not use a function for this. But If I Did, Here's How It Happened:
DEFINE_FUNCTION closePopups(INTEGER nTP){ // passed 0, will close popups on all TP. passed an index, it will close popups on just that tp if(nTP) SEND_COMMAND dvTP[nTP], '@PPX'; else SEND_COMMAND dvTP, '@PPX'; }Thanks you have confirmed I was not going mad, ended up doing it with a for loop style thing.
DEFINE_CALL 'closepps' (integer nIndex) { if(nIndex) SEND_COMMAND dvTp[nIndex],"'@PPX'" //CLOSE ALL POPUPS else SEND_COMMAND dvTp,"'@PPX'" //CLOSE ALL POPUPS } DEFINE_CALL 'closepps' (integer nIndex, dev dvDevs[]) ///Use this if the array of devs changes. { if(nIndex) SEND_COMMAND dvDevs[nIndex],"'@PPX'" //CLOSE ALL POPUPS else SEND_COMMAND dvDevs,"'@PPX'" //CLOSE ALL POPUPS } . . . button_event[dvTp,1]{ push:{ call 'closepps' (get_last(dvTp)); } } button_event[dvTp,2]{ push:{ call 'closepps' (0); } }Jeff
I have all kinds of functions that take an array of devices. Maybe you could post all the code as I have a feeling the problem may lie elsewhere.
DEFINE_FUNCTION fnHWI_DoSend_VT(INTEGER iUI_Indx,INTEGER iVT_Chnl,CHAR iStrMSG[500]) { STACK_VAR INTEGER n ; STACK_VAR INTEGER nTPCount ; STACK_VAR INTEGER nLoopStart ; if(iUI_Indx) { nTPCount = iUI_Indx ; nLoopStart = iUI_Indx ; } else { nTPCount = length_array(dvHWI_UIArry) ; nLoopStart = 1 ; } for(n = nLoopStart ; n <= nTPCount ; n++) { if(nUI_ActiveArry[n] == nDev_Instance)//means nothing here, only for module w/ instances { SWITCH(nUI_TypeArry[n]) { CASE UI_TYPE_G4: CASE UI_TYPE_R4: CASE UI_TYPE_MIO_DMS: { STACK_VAR WIDECHAR cSTRING1[500] ; STACK_VAR CHAR cSTRING2[500] ; cSTRING1 = WC_DECODE(iStrMSG,WC_FORMAT_UTF8,1) ; cSTRING2 = WC_ENCODE(cSTRING1,WC_FORMAT_TP,1) ; SEND_COMMAND dvHWI_UIArry[n], "'^UNI-',ITOA(iVT_Chnl),',0,',cSTRING2" ; } CASE UI_TYPE_G3: { SEND_COMMAND dvHWI_UIArry[n], "'TEXT',ITOA(iVT_Chnl),'-',iStrMSG" ; } CASE UI_TYPE_METKP: CASE UI_TYPE_VIRTUAL: CASE UI_TYPE_UNKNOWN: { //DO NOTHING } } } } RETURN ; }Here's a similar example I use for pop up control:
DEFINE_FUNCTION fnFB_DoPop_Ups(INTEGER iUI_Indx,INTEGER iPOP_ON,INTEGER iPopUP_Indx) { STACK_VAR INTEGER n ; STACK_VAR INTEGER nSetOnce ; STACK_VAR INTEGER nTPCount ; STACK_VAR INTEGER nLoopStart ; if(iUI_Indx) { nTPCount = iUI_Indx ; nLoopStart = iUI_Indx ; } else { nTPCount = sSoundB.nNum_UIs ; nLoopStart = 1 ; } nSetOnce = 0 ; for(n = nLoopStart ; n <= nTPCount ; n++) { if(nUI_ActiveArry[n] == sSoundB.nDev_Instance)//means it on this SB & ACTIVE on page { SWITCH(nUI_TypeArry[n]) { CASE UI_TYPE_G4: CASE UI_TYPE_G3: CASE UI_TYPE_R4: { if(iPOP_ON) { SEND_COMMAND dvUI_Arry[n],"'PPON-',POP_UP_ARRAY[iPopUP_Indx]" ; if(!nSetOnce) { nSetOnce = 1 ; if(iPopUP_Indx > POP_UP_MUSTCONNECT)//then side bar group { sSoundB.nSideBarPopUp = iPopUP_Indx ; } else { sSoundB.nDisplayPopUp = iPopUP_Indx ; } SWITCH(iPopUP_Indx) { CASE POP_UP_NONE: CASE POP_UP_KEYBOARD: CASE POP_UP_ADVSEARCH: CASE POP_UP_CLEARQUEUE: { } CASE POP_UP_CURLISTDISPLAY: { fnFB_DoSend_CHNL(UI_UPDATE_ACTIVE,CH_VIEWINGQUEUE,CH_OFF) ; fnFB_DoSend_CHNL(UI_UPDATE_ACTIVE,CH_VIEWINGLIST,CH_ON) ; fnFB_DoSend_VT(UI_UPDATE_ACTIVE,VT_MAIN_LIST_COUNT,itoa(sSoundB.nListSize)) ; fnFB_DoSend_VT(UI_UPDATE_ACTIVE,VT_MAIN_INDX_RANGE,"itoa(sSoundB.nListIndxLow + 1),' - ',itoa(sSoundB.nListIndxHi + 1)") ; } CASE POP_UP_DISCOSERVER: CASE POP_UP_DISPLAYGROUP://THIS WON,T HAPPEN FOR POPON CASE POP_UP_GETCURSONGINFO: CASE POP_UP_GETSONGINFO: { } CASE POP_UP_QUEUEDISPLAY: { fnFB_DoSend_CHNL(UI_UPDATE_ACTIVE,CH_VIEWINGLIST,CH_OFF) ; fnFB_DoSend_CHNL(UI_UPDATE_ACTIVE,CH_VIEWINGQUEUE,CH_ON) ; fnFB_DoSend_VT(UI_UPDATE_ACTIVE,VT_MAIN_LIST_COUNT,itoa(sSoundB.nQueueSize)) ; fnFB_DoSend_VT(UI_UPDATE_ACTIVE,VT_MAIN_INDX_RANGE,"itoa(sSoundB.nQueueIndxLow + 1),' - ',itoa(sSoundB.nQueueIndxHi + 1)") ; } CASE POP_UP_VERIFYDISCOSERV: CASE POP_UP_ADVSEARCH_iR: CASE POP_UP_MUSTCONNECT: ///make sure this stays the last pop up of this group /////////// SIDE BAR GROUP ////////// CASE POP_UP_DOWHAT: CASE POP_UP_LISTORSEARCH: CASE POP_UP_QUEUEWHAT: CASE POP_UP_SERVERS: CASE POP_UP_SIDEBARGRP: //THIS WON,T HAPPEN FOR POPON CASE POP_UP_TEXTSEARCH: CASE POP_UP_VIEWLISTS: CASE POP_UP_iRADIOLISTS: { } } } } else { SEND_COMMAND dvUI_Arry[n],"'PPOF-',POP_UP_ARRAY[iPopUP_Indx]" ; if(!nSetOnce) { nSetOnce = 1 ; if(iPopUP_Indx > POP_UP_MUSTCONNECT)//then side bar group { sSoundB.nSideBarPopUp = iPopUP_Indx ; } else { sSoundB.nDisplayPopUp = iPopUP_Indx ; } SWITCH(iPopUP_Indx) { CASE POP_UP_NONE: CASE POP_UP_KEYBOARD: CASE POP_UP_ADVSEARCH: CASE POP_UP_CLEARQUEUE: { } CASE POP_UP_CURLISTDISPLAY: { fnFB_DoSend_CHNL(UI_UPDATE_ACTIVE,CH_VIEWINGLIST,CH_OFF) ; } CASE POP_UP_DISCOSERVER: { } CASE POP_UP_DISPLAYGROUP: { fnFB_DoSend_CHNL(UI_UPDATE_ACTIVE,CH_VIEWINGLIST,CH_OFF) ; fnFB_DoSend_CHNL(UI_UPDATE_ACTIVE,CH_VIEWINGQUEUE,CH_OFF) ; } CASE POP_UP_GETCURSONGINFO: CASE POP_UP_GETSONGINFO: { } CASE POP_UP_QUEUEDISPLAY: { fnFB_DoSend_CHNL(UI_UPDATE_ACTIVE,CH_VIEWINGQUEUE,CH_OFF) ; } CASE POP_UP_VERIFYDISCOSERV: CASE POP_UP_ADVSEARCH_iR: CASE POP_UP_MUSTCONNECT: ///make sure this stays the last pop up of this group /////////// SIDE BAR GROUP ////////// CASE POP_UP_DOWHAT: CASE POP_UP_LISTORSEARCH: CASE POP_UP_QUEUEWHAT: CASE POP_UP_SERVERS: CASE POP_UP_SIDEBARGRP: CASE POP_UP_TEXTSEARCH: CASE POP_UP_VIEWLISTS: CASE POP_UP_iRADIOLISTS: { } } } } } CASE UI_TYPE_MIO_DMS: CASE UI_TYPE_METKP: CASE UI_TYPE_UNKNOWN: { //DO NOTHING } } } } RETURN ; }Paul
Some where else in the code during the UI arrays online event I run the DEVICE_ID command as UI's come online to determne there type and store that info in an array. Then in a particular module I can control feedback based on this type depending on that module's particular needs, also whether or not they are on the particular device page and on the particular instance of a module if that applies.
I generally have something like this for all types of feedback, level, channel, VT, etc...
I run this in my main code and pass it to modules as needed.
DATA_EVENT [dvUI_Arry] { ONLINE: { STACK_VAR INTEGER nUI_Indx ; STACK_VAR INTEGER nDeviceID ; nUI_Indx = GET_LAST(dvUI_Arry) ; if(nUI_TypeArry[nUI_Indx] < 2)//RUN IF VALUE IS 0 OR UNKOWN (1). { nDeviceID = DEVICE_ID(dvUI_Arry[nUI_Indx]) ; SELECT { ACTIVE(nDeviceID == 0)://?? No Number { nDeviceID = UI_TYPE_UNKNOWN ; } ACTIVE(nDeviceID >= DEV_ID_METKP_BEGIN && nDeviceID <= DEV_ID_METKP_END)://Metreau Keypads { nDeviceID = UI_TYPE_METKP ; } ACTIVE(nDeviceID >= DEV_ID_MIO_DMS_BEGIN && nDeviceID <= DEV_ID_MIO_DMS_END): { nDeviceID = UI_TYPE_MIO_DMS ; } ACTIVE(nDeviceID == DEV_ID_R4)://R4 { nDeviceID = UI_TYPE_R4 ; } ACTIVE(nDeviceID == DEV_ID_VIRTUAL)://VIRTUAL DEVICE { nDeviceID = UI_TYPE_VIRTUAL ; } ACTIVE(nDeviceID < 256)://G3 panel { nDeviceID = UI_TYPE_G3 ; } ACTIVE(1)://G4 //FIGURE OUT NUMBERS FOR THIS { nDeviceID = UI_TYPE_G4 ; } } nUI_TypeArry[nUI_Indx] = nDeviceID ; fnUI_DeBug("'UI Device: ',fnDEV_TO_STRING(dvUI_Arry[nUI_Indx]),' is a ',UI_TYPE[nDeviceID], '. ** UI Type #',itoa(nDeviceID),' **. >-Line-<',itoa(__LINE__),'>'") ; } } } DEFINE_CONSTANT //UI CONSTANTS & TYPES #DEFINE UI_TYPE_CONSTANTS UI_OFF_PAGE = 0 ; UI_ON_PAGE = 1 ; UI_UPDATE_ACTIVE = 0 ;//OTHERWISE THE UI INDEX IS REQUIRED UI_TYPE_UNKNOWN = 1 ; UI_TYPE_METKP = 2 ; UI_TYPE_MIO_DMS = 3 ; UI_TYPE_R4 = 4 ; UI_TYPE_G3 = 5 ; UI_TYPE_G4 = 6 ; UI_TYPE_VIRTUAL = 7 ; CHAR UI_TYPE[][9] = { 'Unknown', //1 'Keypad', //2 'Mio_DMS', //3 'R4 Remote', //4 'G3 Panel', //5 'G4 Panel', //6 'Virtual' //7 } ;Here's my current collection of device id's. Still need the newer panels.
DEFINE_CONSTANT //DEVICE ID's #DEFINE DEV_ID_CONSTANTS /////////////////////////////////KEYPADS NO TEXT SUPPORT DEV_ID_METKP_BEGIN = 169 ; DEV_ID_MET6N = 169 ; DEV_ID_MET7 = 170 ; DEV_ID_MET13 = 171 ; DEV_ID_METKP_END = 171 ; /////////////////////////////////KEYPADS MIO DMS TEXT & UNI SUPPORT DEV_ID_MIO_DMS_BEGIN = 304 ; DEV_ID_MIO_DMS1 = 304 ; //Mio-DMS Keypad (non-color, non-touch display with buttons) DEV_ID_MIO_DMS2 = 305 ; //Mio-DMS Keypad (non-color display with touch and slider) DEV_ID_MIO_DMS3 = 306 ; //Mio-DMS Keypad (color display with touch and slider) DEV_ID_MIO_DMS4 = 307 ; //Mio-DMS Keypad (color display with touch, slider, and intercom) DEV_ID_MIO_DMS_END = 307 ; /////////////////////////////////G3 PANELS DEV_ID_G3_END = 256 ; /////////////////////////////////G4 PANELS DEV_ID_CA15 = 281 ; //NXx-CA15 DEV_ID_CV15 = 282 ; //NXx-CV15 DEV_ID_CA17 = 283 ; //NXx-CA17 DEV_ID_CV17 = 284 ; //NXx-CV17 DEV_ID_7500 = 288 ; //MVP-7500 DEV_ID_8400 = 289 ; //MVP-8400 DEV_ID_CV7 = 290 ; //NXx-CV7 DEV_ID_CV10 = 291 ; //NXx-CV10 DEV_ID_1200 = 294 ; //NXx-1200 DEV_ID_12VG = 295 ; //NXx-1200VG DEV_ID_15VG = 296 ; //NXx-1500VG DEV_ID_17VG = 297 ; //NXx-1700VG DEV_ID_CV5 = 313 ; //NXD-CV5 DEV_ID_7500TC = 314 ; //MVP-7500 with Touch Controller DEV_ID_8400TC = 315 ; //MVP-8400 with Touch Controller DEV_ID_CV7TC = 316 ; //NXx-CV7 with Touch Controller DEV_ID_CV10TC = 317 ; //NXx-CV10 with Touch Controller DEV_ID_12TC = 318 ; //NXx-1200 with Touch Controller DEV_ID_12VGTC = 319 ; //NXx-1200VG with Touch Controller DEV_ID_15VGTC = 320 ; //NXx-1500VG with Touch Controller DEV_ID_17VGTC = 321 ; //NXx-1700VG with Touch Controller /////////////////////////////////R4 DEV_ID_R4 = 322 ; /////////////////////////////////CONT G4 PANELS DEV_ID_8400i = 323 ; //MVP-8400i DEV_ID_CV7iTC = 324 ; //NXx-CV7i with Touch Controller DEV_ID_CV10iTC = 325 ; //NXx-CV10i with Touch Controller DEV_ID_5200i = 329 ; DEV_ID_5150 = 329 ; DEV_ID_5100 = 329 ; DEV_ID_500i = 331 ; /////////////////////////////////NI MASTERS DEV_ID_NI2_3_4000_M = 285 ; //NI-2000/3000/4000 (Master) DEV_ID_NI2_3_4000_D = 286 ; //NI-2000/3000/4000 (Device) DEV_ID_NI700 = 298 ; //NI-700 DEV_ID_NI2_3_4000 = 299 ; //NI-2000/3000/4000 DEV_ID_NI900 = 312 ; //NI-900 /////////////////////////////////ENT VST - C DEV_ID_ENVVSTC = $E5 ; DEV_ID_VIRTUAL = 65534 ;
