MET-ECOM - image size
Specs for Met-Ecom mention: Video QVGA 320x240...
Is there a way to have it displayed on a TP with an 'enlarged' window (even though you'll probably loose some quality in the process...)?
This small size is really not a great argument for the device.
You can use the scaling option in TPD dynamic images. I have been somewhat disappointed in this device though. You have to make sure that when you mount it its at exactly the right level, since there is no way to move the camera up and down. The last one I programmed, the installers put it in without any consideration of the camera and now anyone who is at the front door can only be seen from the shoulders down. The client is getting good at identifying people by their body shape though.
Thank you for the info - did not know this option existed.
8400/i, CV7, CV10: Upscaling is fixed to 2x original size (640x480) - video will be cropped if the window is smaller
500i, 5200i: Video will be upscaled to the size of the window (but keep your window at the same aspect ratio to avoid black bars)
As someone pointed out, upscaling will not increase clarity as it is simply pixel replication. One more important note - if you do mark your MET-ECOM resource as a "Dynamo Resource", be sure to replace "stream_cam_wg" with "stream_cam_eth" - the latter tells the MET-ECOM to feed video at a higher rate.
What is the resolution of stream_cam_eth?
The resolution is the same - 320x240.
