Using GLH command
I'm playing around with the GLH command so I can adjust the upper bargraph level depending on the source for the volume. I have tried but so far I am not able to get it to work. It appears to be a pretty straight forward command but BG on my TP never seems to adjust to the upper level I assign it using the command. Is there somewhere special I should have this command located ? right now I have it in the online event section for the TP. Any help would be appreciated.
    My first question is: Do you have an address port/code set on the button?
    I am loading a touch panel to verify functionality here. I will let you know in a few minutes if it works.
    Just tested and it works using the following command: "'^GLH-1,100'" via diagnostics.
    I tried the diag. but the TP BG never changed. Sounds like I don't have the BG setup correctly. I have the level assigned, I assigned the address number but still not working. Is there anything else that needds to be assigned?
    Not that I can think of. Can you copy and paste the button you are trying to control into a panel file with one page and that button on the page? I will load it here and try it.
