variable text string
i'm trying to get the numbers on a keypad to display in a variable text button (for a audio conference system...to see the number as it is being dialed).
the touch panel is a VPN-CP.
i could create a keypad button, but that pops open a keypad and closes it after pushing "enter", which i don't want to do. it also does not have the star and pound symbol, which may or may not be needed.
so, i created my own keypad, sending the numbers to the Vortex EF2211.
how do i create a string, add the next character entered, have the full number displayed (as number buttons are being pushed)?
thanks.
  • HedbergHedberg Posts: 671
    This should give you an idea of how it can be done.
    BUTTON_EVENT[vdvAllVortexTP,nPhoneNbrBtn]
    	PUSH:
    		local_var INTEGER nBtnIdx
    		nBtnIdx = GET_LAST(nPhoneNbrBtn)
    		IF(!flagPhoneStatus) //CHECK TO SEE IF THE PHONE IS ON HOOK
    			IF(nBtnIdx = 12)
    				sNumberToDial = "sNumberToDial,35"
    			ELSE IF(nBtnIdx = 11)
    				sNumberToDial = "sNumberToDial,42"
    			ELSE
    				sNumberToDial = "sNumberToDial,ITOA(nBtnIdx-1)"
    		ELSE IF (flagPhoneStatus)
    			IF(nBtnIdx = 12)
    				CLEAR_BUFFER sNumberToDial
    				SEND_STRING vdvAllVortexTRS232,"sIDString,sTelcoFnct[9],sNumberToDial,13"
    			ELSE
    		SEND_COMMAND vdvAllVortexTP, "'@TXT',2,sNumberToDial"
  • drewbertdrewbert Posts: 3
    text box
    thanks so much for that guidance.
    here is what i ended up with...
    (would love to get feedback on this as well.)
    BUTTON_EVENT[vdvTP,102] // dial
    PUSH:
    SEND_STRING dvTel_Interface,"'S03PHONE1',13"
    SEND_COMMAND vdvTP,"'PPON-phone_text_box'"
    BUTTON_EVENT[vdvTP,103] // hang-up
    PUSH:
    SEND_STRING dvTel_Interface,"'S03PHONE0',13"
    SEND_COMMAND vdvTP,"'PPOF-phone_text_box'"
    SEND_COMMAND vdvTP, "'@TXT',4,''"
    BUTTON_EVENT[AUD_CNF_CNTRL]
    PUSH:
    LOCAL_VAR INTEGER nBtnIdx
    nBtnIdx = GET_LAST(AUD_CNF_CNTRL)
    IF(nBtnIdx = 11)
    sNumberToDial = "sNumberToDial,'*'"
    SEND_STRING dvTel_Interface,"'S03DIAL*',13"
    ELSE IF(nBtnIdx = 12)
    sNumberToDial = "sNumberToDial,'#'"
    SEND_STRING dvTel_Interface,"'S03DIAL#',13"
    ELSE
    SEND_STRING dvTel_Interface,"'S03DIAL',ITOA(nBtnIdx-1),13"
    SEND_COMMAND vdvTP, "'@TXT',4,sNumberToDial"
    ...sry, not sure how to format it to appear in the post the way yours did.
    phone number entry
    any hints on how to have dashes or spaces show up?
    as in, if the first digit is 1, follow it with a space; after three digits, follow with a space; etc.
    thanks.
