Long shot trick
Anyone know a way to set an address code from code when in the touch panel file all that is configured is a channel code? The reverse would be ok too.
  • truetrue Posts: 307
    Anything in the Programming tab of a button needs to be defined in the touchpanel file.
    true wrote: »
    True,
    Not true. Feedback can be changed from code.
    a_riot42 wrote: »
    Same with the level ranges.
    Without an address code though we?re SOL, there?s no way to point to the object.
    Ah, yes, I did know feedback could be changed, but didn't know about level ranges. Sorry about that. :/ Still, I don't think you can do what you want to do.
