Anyone need unix timestamps or pretty dates (the calendar kind)?
I was bored again today - so I decided to write a netlinx time/date to unix timestamp (and back) converter and a formatted date function similar to php's date() to make use of a timestamp. If you're interfacing with devices that want a unix timestamp, or want prettier / different dates for touchpanels, this code might help.
For instance, this code:
Unix timestamps are provided adjusted to the local timezone (ala clkmgr or a specified offset) with unixtime(LDATE, TIME) or unixtime_now(), and not adjusted (UTC-based) with unixtime_utc(LDATE, TIME). DST via clkmgr is only barely supported - when it's on, it applies a +1hr offset... anyone have better documentation for the clkmgr_ functions? Right now my fmt_date() isn't timezone-aware so it wants a UTC based time, so don't get too confused with the example above
Even if you don't care about unix timestamps, having something more than the built-in date types on panels that's easily adjustable might appeal to you. Yay ordinal suffixes!
I've also got functions to convert unix timestamps (say, from a remote webserver or device) back into AMX-compatible DATE/LDATE/TIME strings - unixtime_to_netlinx_ldate(), etc. if you have these date types and would prefer to work with AMX date/time strings.
Since I'm working solely residential now, I wrote (not on company time, sigh) a no-ip sync module and I may also write a dyndns-protocol compatible module. Anyone have use for these?
edit: 10000th post in this forum
send_string 0, fmt_date('\T\h\e \d\a\t\e \i\s l, F jS Y g:ia \D\a\y #z', unixtime_utc(LDATE, TIME))sends to the console:
(0000752985) The date is Saturday, March 27th 2010 9:12pm Day #85
hi,
timestamp -> date is not working when is a leapyear...
Error on line 558 and 559: in the "unixtime_to_raw_values" Function
if (unixtime_year_is_leapyear(yr)) {
//w2 = UNIXTIME_SECONDS_PER_DAY
>do not overwrite this stack_var!
//w = w - w2
w=w - UNIXTIME_SECONDS_PER_DAY //do this way
for this... is very useful... for me
The underlying OS has all the time/date functions you could ask for. Too bad there is no exec() function.
