Installing IREdit on Windows 7 x64
I'm trying to install IREdit on windows 7, as we're upgrading completely to it shortly. It's the 64 bit version. But I can't seem to install IREdit.
Wise Installation System
! The installation of IREdit 1.0 requires Microsoft .Net Framework v1.1 or higher. You do not have this version or higher installed on your system. Please install the IREdit System Files to your system and try the installation again.
The installation will now terminate.
[ OK ] [ Cancel ]
I have tried running it in compatibility mode (windows xp sp3 and as admin)
  • PhreaKPhreaK Posts: 966
    As the error message mentions, you need to download and install the IREdit System Files first.
  • Jorde_VJorde_V Posts: 393
    PhreaK wrote: »
    I forgot to add that I tried that, there I get the following message:
    Microsoft .Net Framework Setup
    ! This installation requires the Microsoft .Net Framework to be installed on your system.
    [ OK ] [ Cancel ]
    Obviously this is installed, the installer doesn't agree though.
    Edit: Ah in compatibility mode it begins installing the .net framework.
