Bitwise Operations Q
Pardon my ignorance here, but...
How do I get the least significant bit by BANDing with $FF? I wrote it out longhand, and when I BAND $FF and $FC, I get $FC. Since FC is greater than a byte (equal to 252) and I need to stay under a byte, do I get rid of the $F with something like an LShift?
  • yuriyuri Posts: 861
    you can use LSHIFT or RSHIFT 4 :)
  • PhreaKPhreaK Posts: 966
    You get $FC back from that because it is less than a byte. The max value of a byte is 255 (2^8 values) so $FC (252) < $FF (255). If you are wanting the least significant *bit* you'll need to band with $1 if the data is big endian, or $80 if it is little endian.
  • jweatherjweather Posts: 320
    PhreaK wrote: »
    That's not what big/little endian means. Endianness almost always refers to byte order, not bit order. If you have a two-byte quantity 0x0142 (decimal 322) it can be sent over the wire as $01,$42 (big endian, or most significant byte first) or $42,$01 (little endian, or least significant byte first). The bit order is always the same. Intel processors are little endian because they store the least significant byte of a word in the lowest memory address (or "first"). http://en.wikipedia.org/wiki/Endianness
  • mpullinmpullin Posts: 949
    This thread has too many chiefs and not enough endians.
    @jweather
    You can still have bit endianness. Given by time anything reaches NetLinx's level of abstraction is should be big endian (MSB 0).
    Back to the original question though. It sounds as though you may be getting confused with a hex representation of byte. A value like $FC is not two bytes (F and C), it is instead a representation of a single value comprised of 0xF (15 in base 10) times 16^1 for your highest 4 bits and 0xC (12 in base 10) times 16^0, which gives you bits 3 through 0. In order to get the least significant byte of a value that is in NetLinx land you're already doing the right thing by band'ing with $FF.
  • vegastechvegastech Posts: 369
    Sorry, I'm still a little confused. I guess what I meant to ask is if I have something that is over a byte, like decimal 300( or $12C i think), do I still BAND with $FF to get the least significant byte, or an LSHIFT? I tried that, and my calculations must be off, because when I did an LSHIFT on $156, I got $56, but when I did it on $157, I got $58. I need to drop the first value above 100, so instead of 110, I need to report 10. Can I do that?
    It's a confusing topic, be worried if you're not confused :)
    It helps to try and visualise what is actually going on. All endianness guff aside, lets just say you've got the value 0x12C:
    hex     0---------  1---------  2---------  C---------
    binary  0  0  0  0  0  0  0  1  0  0  1  0  1  1  0  0
    bit     15          11          7           3        0
    BAND'ing basically says 'tell me what bits are high for values on both sides of the BAND operator'.
    In order to get the least significant byte BAND'ing the value with 0xFF means that anything above bit 7 (where $FF finishes) is truncated and you are just getting the value from bits 7 through 0.
    hex     F---------  F---------
    binary  1  1  1  1  1  1  1  1
    bit     7           3        0
    So when you band:
    binary (0x12C)  0  0  0  0  0  0  0  1  0  0  1  0  1  1  0  0
    binary (0xFF)   0  0  0  0  0  0  0  0  1  1  1  1  1  1  1  1
    bit             15          11          7           3        0
    You get:
    hex     0---------  0---------  2---------  C---------
    binary  0  0  0  0  0  0  0  0  0  0  1  0  1  1  0  0
    bit     15          11          7           3        0
    LSHIFTing (<<) and RSHIFTing (>>) allows you to shift bits left or right by how ever many places you specifiy on the right hand side of the operator. By themselves they're probably not what you're after for getting the LSB, however they're usefull operation for creating masks to use in BAND, BOR etc operations.
    You question about dropping anything above 100 is a completely seperate issue to anything to do with these bitwise operations. To do that you'll most likely be wanting the mod (%) operator. This will give the remainder of a value divided by another. So in the case of getting components of a number in base 10 under 100 you could use somethine like number % 100. There's plenty of info on it in the help files.
    vegastech wrote: »
    You will never get a higher value than that which you use to BAND against. FF (or 255) means that all eight bits (valued as 1,2,4,8,16,32,64,128) are high or active or set or whatever. BAND compares the individual bits of this value with another and returns the bit values of all bits that are high in the both values of the comparison.
    11111111 BAND
    11111111 =
    11111111
    10101010 BAND
    11111111 =
    10101010
    (something higher than FF)
    11111111011 BAND
    00011111111=
    00011111011
    The last example shows getting the lower eight bits as often used in checksum calculations.
    Hope this helps.
    Yay I get it! (Until I don't)
    Thanks to TurnipTruck, Phreak, and True for helping to explain this rather difficult topic (at least for me!). I wasn't putting together the fact that $157 was in fact a 16 bit integer, and not an 8 bit. Rookie misconception (or misremembering), I suppose. Now that I can actually visualize (and more importantly draw them on a sheet of paper *wink*) bit values (or bytes, etc) above FF, I think I will have an easier time. Thanks again for everyone's .02 cents!
  • KennyKenny Posts: 209
    Wow, I my head is really starting to spin. I've never fully grasped the bitwise stuff. I seem to have to relearn it when a project needs it.
    For more info checkout tech notes 210, 457 and 518.
    Kenny
