Inconsistent DEVCHAN Event behavior
Howdy Everyone!
So I've got an array of devchans. Not too complicated. However, once I put it into a multidimensional array, odd things start happening. Here is the code:
The BUTTON_EVENT[SOURCE_BUTTONS[1][1]] and BUTTON_EVENT[SOURCE_BUTTONS[1][2]] event works perfectly, but the BUTTON_EVENT[SOURCE_BUTTONS[1]] never fires. They're both using the same parts of the array which were assigned at the same time. Both utilize the REBUILD_EVENT() command.
Am I going crazy or should this work??
--Mitch
For reference, this is working perfectly in the same test program just a few lines after the above code:
DEFINE_VARIABLE
DEVCHAN SOURCE_BUTTONS[1][2]
DEFINE_START
SOURCE_BUTTONS[1][1] = {dTP1,3};
SOURCE_BUTTONS[1][2] = {dTP1,4};
REBUILD_EVENT()
DEFINE_EVENT
PUSH:
SEND_STRING 0,"'Button number ',BUTTON.INPUT.CHANNEL,' was pressed with SOURCE_BUTTONS[1]'";
PUSH:
SEND_STRING 0,"'Button number ',BUTTON.INPUT.CHANNEL,' was pressed with SOURCE_BUTTONS[1][x]'";
^^Shown is not the full code used, just a small modified portion for demonstrationThe BUTTON_EVENT[SOURCE_BUTTONS[1][1]] and BUTTON_EVENT[SOURCE_BUTTONS[1][2]] event works perfectly, but the BUTTON_EVENT[SOURCE_BUTTONS[1]] never fires. They're both using the same parts of the array which were assigned at the same time. Both utilize the REBUILD_EVENT() command.
--Mitch
DEFINE_VARIABLE
DEVCHAN TEMP_BUTTON[] =
{dTP1,1},
{dTP1,2}
DEFINE_EVENT
BUTTON_EVENT[TEMP_BUTTON]
PUSH:
SEND_STRING 0,"'Button number ',BUTTON.INPUT.CHANNEL,' was pressed with TEMP_BUTTON'";
