Converting Long to Integer
I created a long to hold a maximum number of seconds, and now I want to convert it into hours. How do I do that? I get a compiler error stating ERROR: converting type[long] to [integer]. I was going to try and just leave the value a LONG, but I don't think I can convert a long to ascii, can I? I need to update variable text fields.
However in the future if you're wanting to stuff a value into an integer that was originally stored as a long and you're absolutely certain that it is less than 65535 (2^16) you can use TYPE_CAST()
