Wait_Until Question
I have a wait_until placed in each of my source functions, but it seems that the wait_until only triggers when the system was previously off, not while it is on:
DEFINE_FUNCTION fcnDVD()
IF (nPower = 0) //Room Off
//turn room on, set waits/timelines, etc
fcnPwrOn()
WAIT_UNTIL(!TIMELINE_ACTIVE(tl_ProjWarmUp))
SEND_STRING dvPROJ, "cProjComp,fcnCheckSum(cProjComp)" //proj component input
nCurrentSource=1
My hope here was that the wait_until would work as a sort of flag when the system is already on. Am I just coding this wrong, or do I need a different flag to check other than the active/inactive timeline? I figured the timeline was good because it has the necessary 45 sec. delay aready in it. 0
This would also be easier to track in debug for troubleshooting purposes.
BUTTON_EVENT[dcSources] //latches source buttons together { PUSH: { nCurrentSource = GET_LAST(dcSources) IF (nPower = 0) //<----------------------------------Sneaky!!!! { //start the projector polling, send proj pwr, update var text fields SWITCH(GET_LAST(dcSources)) { CASE 1: fcnDVD() CASE 2: fcnCamera() CASE 3: fcnSAT() } } } }Switch-Case doesn't exactly work here if the room is already on....Guess that's why I should really proofread my code as I do revisions!
