VPT-CP Calibration
in AMX Hardware
My VPT-CP calibration is out, what are the steps to get it into calibrate mode? Can I connect directly with RS232 cable and send a command? Should I use NS?
Use 38400 baud (this is the default programming port speed in setup), open a terminal session, and then type (invisible) CALIBRATE<enter>. must be uppercase.
Pinout for the adaptor (DB9 f-f crossover cable additionally required):
Tip
Pin3 DB9 male
Ring
Pin2
Sleeve -- Pin5
Thanks Marc,
I have done this and it works fine. Do you know why it happens?
On the G3 panels, unfortunately the power-and-hold only works to go to setup, but it will not go on to calibration.
