DENON TU604?
Has anyone integrated one of these yet and if so what's your opinion of the unit. Anything to be concerned about as I write a module for it? Seems fairly straight forward but sometimes Denon products don't function as documented so any insight beyond what's published would be appreciated.
  • greinertgreinert Posts: 1
    vining wrote: »
    I am about to integrate one of these units also, did you have good success with the unit?
    So far so good. My module seems to be working fine but I haven't implemented the "disco when idle" or the "disco when idle, then re-connect" routine that's been recommended in another thread covering Denon IP comms (Denon has a bit of an issue with IP comms). I haven't had a chance to post the code yet but if your interested in it just shoot me your email address. Oh since I'm in the US I didn't do anything for DAB, the code structure is set up for it but pasring and stuff hasn't been done and I'm not using HD radio in the job I wrote this for so this is probably somewaht incomplete too? At least feedback, maybe?. Hmmm, I don't remember so good anymore. :)
    Added:
    The code should be structured for either IP or serial so IP isn't required if one chooses not to use it. I like to keep my serial ports free for things that don't give me choices.
