Remotely Connect to a Master
I am not a networking guru so I don't even know where to start researching this. What do I need to do to remotely connect to a customer's master through the internet? More specifically, what equipment do I need and how do I setup the connection?
Once you know what IP your remote site is at, you will want to direct (port forward) traffic on the netlinx 1319 port to your master. Your router should have a rules section that will allow you to set up the port forwarding. In some cases, you have to create the 1319 rule one page of the router configuration and then go to another to map what you created to the IP address of the master.
So my understanding is that...
-I setup port forwarding for port 1319 in the customer's router and I use the master's IP as the server IP address
-Then, how do I remotely connect to that from my office?
Netlinx Studio PC - Remote Public IP Address (Static Public Address of client router or DynDNS Name)
Client System Router - Fixed Static Public IP Address (or dyndns name). Forward all traffic on port 1319 to local LAN address of Master (ie 192.168.1.100)
AMX Master - Fixed Static Private IP Address as set in Router (ie 192.168.1.100)
Actually I just found out that they only allow a static for business accounts. So that dyndns.org should help.
That's a great visual. Once I have everything set up like this and I'm in front of NetLinx Studio what do I use for the connection settings? Do I just set it to TCP/IP and then use the IP address of the customer's router? What would I use if I was tracking it with DynDNS?
so an example url for your master would be nameyouregistered.getmyip.com
I would uncheck the PING master box when setting up the address. I can never get it to work when that is checked.
Another way of connecting which is significantly easier is through VPN. If you spec out routers that support VPN, then you can essentially login or "tunnel" into the network at the installation site and you'll receive a local IP address. From there you can communicate with all the devices on that remote network as though it was local.
-John
-John
The other point to note with port forwarding is that you only need access to a single master (if you have multiple masters) and this will allow you to download to all masters and TP's via a single address.
Great tip for the emailed security logs, John!
I have a telnet app on my iphone and this has helped on several occations.
You can also port forward to panels for VNC. I suggest adding a VNC password to the panel, but it is super handy.
