Home AMX Technical Discussion
How can I transfer discrete IR command to .IRL file?
Hi all,
As title , How can I transfer discrete IR command to .IRL file?
J.Y.
    J.Y. wrote: »
    Hi all,
    J.Y.
    I'm not sure if I understand the question... but here we go...
    If you have a discrete IR code in Hex form that you wish to put in your set of AMX IR codes, you simply open the IR file in IREdit, select and empty channel cell, hit the Hex button which will take you to the Hex Wizard.
    From there you can give the code a name (like 'Power On') and paste in the HEX code.
    Then, save the file, load it into the master and test it out.
    Hope that helps.
    e
