Re-enable Telnet Access Remotely?
I have a 5200i that won't alllow me to telnet in. Is there an easy way to re-enable telnet access remotely? I suppose I could put a button on the touchpanel to access the setup page then VNC into it and change the telnet setting, but I'm lazy and I don't want to modify a file, load it, VNC in, and then reload it unless I have to :o.
Thanks!
-John
  • PhreaKPhreaK Posts: 966
    If it's connected to a master telnet into the master and shoot the panel a 'SETUP' command, VNC into the panel and enjoy.
    You can also just send the setup command from NS control device aimed at the TP if that's any easier and do the VNC thing.
  • Thank you gentlemen for 2 very excellent suggestions. My brainpower was completely spent that day. I ended up using Vining's suggestion of popping a setup command in "control a device" and VNC'd in.
    -John
