Page tracking on NXD 1000Vi
Hi
Anyone come across this one?
Page tracking is turned on, when you initially do this - a command comes back from the panel stating the current page and then after that NOTHING! In diagnostics, you can see commands go out but not coming back?????
Usually I work using virtual devices combined with the real device, but in this instance I can't because of one of the modules I've been forced to use - so I am working with the real panel device, no virtual combination
However, I did a test and combined it with a virtual and lo and behold - it works!!! not that this helps me but its a bit bizarre, to say the least!
Any takers???
thanks in advance
D.
Any takers???
thanks in advance
D.
Hi Dave
I've always used page tracking with a combined panel (as in combined with a virtual device) and page tracking works from code page flips.....so if what you are saying is true, why does that work???
Cheers
I can't speak to how it works with combined virtuals really; I don't use them anymore. It may also be a new thing, or even panel specific. My habit used to be to use page flips in the panel itself almost exclusively, and the times I didn't it wasn't necessary to track. But I have migrated towards using code, and this is simply what I have noticed and verified, at least with 435's and R4's. I don't get the tracking message from code flips, period.
I had the same problem. NSS-Vote with code-based page flips. I had two NXT-1700VG panels that needed to track, but I wasn't getting the necessary strings back from the panels. I found that a panel will respond with its current page/popup when issued a 'TPAGEON' send_command. I added this command on the release of a button_event [dvTP,0] and it all worked.
good luck.
Stephen
You only need to put TPAGEON in the ONLINE event. It shouldn't need to be sent over and over again.
