One panel, multiple masters...
I have 3 rooms with their own masters and panels. They are all the same. In a fourth room there is another panel that needs to monitor and control the other 3 rooms. So I just have it connect to one of the masters and do master to master with the other two.
I'd like to use the same TP file in the 3 rooms, but I don't see how the 4th panel will be able to tell which master the feedback is coming from if the other 3 panels use the exact same channel numbers and are only independent because they are on different system numbers.
Without more specifics I really don't know what to say
Another method might be to set a flag if the 4th touch panel is "viewing" each master and when the flag is activated, update the feedback and respond to button pushes accordingly.
Hope this helps,
DEV dvtp_1[]= {dvtp, dvtp_4}
Something Like that
//in first master...
dvTP1 = 10001:1:1
dvTP4_1 = 10002:1:1
dvTPs = {dvTP1 ,dvTP4_1}
//second master
dvTP2 = 10001:1:2
dvTP4_2 = 10002:2:1
dvTPs = {dvTP2 ,dvTP4_2}
The buttons on the "master" touchpanel will have port numbers corresponding to the system number of the buttons on the related touchpanel.
