Viewing Lutron Homeworks Driver Strings over TCP/IP?
Are the Lutron Homeworks serial driver strings visible over TCP/IP? For instance, if I create a serial driver on the Homeworks panel that's fired off on a Keypad Button Press, I know I can monitor it through the RS232 port, but is the driver also visible over TCP/IP when it's fired? Is there anything that needs to be set up on the Homeworks processor other than 'DRMON'?
I'm trying to get a Homeworks panel to fire off a customized string when a keypad button is pressed, but I'm not seeing any data over telnet.
Sorry if the question doesn't make sense, let me know and I'll rephrase.
  • Incidentally, this is more of an academic thread. I'm monitoring the KBP which is just as easy.
    --John
    Unless Lutron has changed something, the Serial Drivers do not send to the IP connections. I had to do what you are doing and just look for keypad button pushes, releases and holds.
    Yeah to the best of my knowledge I've only ever done this over a seperate serial connection from the Lutron processor. My normal HomeWorks/AMX comms are usually over IP but the times I've used Lutron keypads to work audio or anything else using driver strings was by using a serial driver and assigning it to the 232 port I wanted to use and sending my own created driver strings.
    If you just want to trap keypad button presses & releases instead of creating driver strings you could just enable keypad button monitoring:
    L232> KBMON
    Keypad button monitoring enabled
    Example
    Someone presses button 1 on processor 1, link 4, keypad address 4
    KBP, [01:04:04], 1
    Example
    Someone releases button 1 on processor 1, link 4, keypad address 4
    KBR, [01:04:04], 1
    Someone holds button 1 on processor 1, link 4, keypad address 4
    KBH, [01:04:04], 1
    Then just trap the these strings and do what ever you want. I've never done it this way, not sure why, I guess I felt I'd rather keep thing seperate.
  • Thanks guys!
