DVX Commands
Any one ever use the commands to control the line mix level to the line output?
I think the command is the XPOINT- command but I'm not real sure.
The command that I am using is not working.
Here is the command.
SEND_COMMAND dvIN_2,"'XPOINT-',itoa(nVolPGM),',',itoa(nINPUTS),',2'"
I'm not real sure what device to send it to. This is the 2nd input/output device. Should I be using dev I/O 1 instead.
Thanks for your help.
