Home AMX User Forum AMXForums Archive Threads Tips and Tricks
How to make the volume ramp with calculation.
Hi all..
I have a Mixer / volume control which i want to use to change the volume. the problem is that it needs a string where the last to digits represents the ascii of the numbers 0 - 255. How can i make this ramp using calculation. i've added the code i'm trying to use. and a cutout from the manual of the mixer.
Thanks in advance.
Sent to Unit
!04SR01XX<CR>
Set Source Volume
XX = Volume setting ranging from 00 – FF with FF being volume control at
full and 00 being minimum volume. The 256 volume steps are internally
scaled in the IN600 from the 65 available volume steps.
Received from Unit
*01SR01XX<CR>
Source volume value
See note below for more information on volume scaling
BUTTON_EVENT[dvTP,cVolButs]//998=VOL NED, 999=VOL OPP
    hold[1,repeat]:
	SWITCH(BUTTON.INPUT.CHANNEL)
	    CASE 999:	SEND_STRING dvMixer,"'!04SR01'(nVolume+01),$0D"
	    CASE 998:	SEND_STRING dvMixer,"'!04SR01'(nVolume-01),$0D"
DATA_EVENT[dvMixer]
    STRING:
	SELECT
	    ACTIVE(FIND_STRING(DATA.TEXT,'*01SR01',1)):
		nVolume = Right_String(DATA.TEXT,2)
		SEND_LEVEL dvTP,5,nVolume
		SEND_COMMAND dvTP,"'^TXT-5,0,',ITOA((nVolume*100)/255),'%'"
  • I've been reading post around the forum and changed the code a bit?
        hold[1,repeat]:
    	    CASE 999:	SEND_STRING dvMixer,"'!04SR01',ITOA(nVolume+01),' ',$0D"
    	    CASE 998:	SEND_STRING dvMixer,"'!04SR01',ITOA(nVolume-01),' ',$0D"
  • jweatherjweather Posts: 320
    To turn 255 into FF, you're looking for itohex(). You will also need to change nVolume each time, otherwise the volume will never change more than one step, assuming nVolume isn't getting set by feedback from the switcher:
        hold[1,repeat]:
    	    CASE 999:	{
    	    	    nVolume++
    	    	    SEND_STRING dvMixer,"'!04SR01',ITOHEX(nVolume),' ',$0D"
    	    CASE 998:	{
    	    	    nVolume--
    Might want to add some more logic to keep the volume from wrapping around (over 255 or under 0, which would underflow into 65535)
    Try this:
        hold[1,repeat]:
    	    CASE 999:{
    			nVolume++
    			SEND_STRING dvMixer,"'!04SR01',itohex(nVolume),$0D"
    	    CASE 998:{
    			nVolume--
    DATA_EVENT[dvMixer]
        STRING:
            stack_var char sIncMsg[50]
            while(find_string(data.text,"$0D",1){
    		sIncMsg = remove_string(data.text,"$0D",1);
    		SELECT
    		    ACTIVE(FIND_STRING(sIncMsg,'*01SR01',1)):
    			remove_string(sIncMsg,'*01SR01',1);
    			nVolume = hextoi(sIncMsg);
    [/QUOTE]
    I think that will do what you need. For the raise/lower buttons, you were not saving the value changes to the volume, so the volume would never change. You might also want to consider moving more than a value of 1 each time. If you are happy with the ramp speed, you could just change to nVolume = nVolume +/- 5 and increase the hold time to 5. This will reduce traffic considerably and I doubt you will notice the difference audibly.
    I also changed the incoming string handler a little. First, you were not accounting for the <CR> at the end of the string, so you were only grabbing the last hex digit in the volume, not both of them. Second, I would recommend using CREATE_BUFFER and parsing the buffer on a string event. The code provided can easily be changed to work on a buffer variable. This will handle messages that are split by the processor into two or more string events.
  • I'll just delete that reply since it got outdated by a new respons.
    The button event looks good and i understand what it's doing. But i will have a problem with the data_event if it does not work. cause i have no idea what it actually does. i'm not to experienced so i'm trying to keep the code simple so i can modifie it myself if needed. Would the previos data_event work.
    Thank you very much for your help.
  • I think maybe i understand it afterall. I just had to sink in the information first.
    Post here if you have problems getting the volume to display correctly. The code I posted will handle two messages sent in one string event, but it will not handle a message that is split between two string events.
  • Thank you very much, tested the code first time today, and it worked. Only problem wich probably isn't a problem is that the string ramps beyond what the mixer understands and i have to wait to get back to a decimal it understands before it starts ramping back up or down depending on which way i went.
    I guess no one will go to max or min so its really no big deal.
    espen
  • jjamesjjames Posts: 2,908
    Don't forget that when using itohex(), 0-15 will only return one one character, ex: decimal 13 return "D", not "0D", so if your device is looking for a hex value two characters long, you'll have to do some formatting. Basically, you can format it like so:
    s_theHexValue = right_string("'0',itohex(i_theDecValue)",2);
    This will make sure it's always padded by a zero when needed.
    jjames wrote: »
    As will this:
    s_theHexValue = format('%02X',i_theDecValue)
  • jjames wrote: »
    Thats probably why the feedback stops at 6 percent, where in this code will i do the formatting?
    DATA_EVENT[dvMixer]
        STRING:
            while(find_string(data.text,"$0D",1))
    	    SELECT
    		    SEND_COMMAND dvTP,"'^TXT-5,0,',ITOA((nVolume*100)/254),'%'"
    Well - first, make sure the device is not responding to the single hex value, for example '!04SR01D' instead of '!04SR010D'; if it's not responding to the former - then you'l definitely need to format it when it's sent: so in Jeff's example, it'd be here -
    SEND_STRING dvMixer,"'!04SR01',right_string("'0',itohex(nVolume)",2),$0D"
    Joe - I *ALWAYS* forget about the FORMAT command, probably because the documentation is poor in my opinion, and needs more examples with what you could do with it. It confuses the heck out of me, so I just do stuff like I posted. :-)
