Keep travk of popup`s
Hi guys
I got a client who want a button, that activates a popup, to be active as long as the popup is open.....
How do I track whether a popup is active/open or not ?
    Send the TPAGEON command to the panel in it's online event. Then, create a STRING handler for the panel. In the DATA.TEXT whenever a STRING event occurs will be a "PPN-<popup name>" for every time the popup appears, and a "PPF-<popup name>" for when it goes away. Parse those and use the data to track your pages.
    Alternately, if the popup can only be called with a button press, and is modal, and can only dismissed with another button press, you can use the button events to track it.
  • Why not just put the button or a copy of the button on the popup page?
