Underground waterproof tv lift?
A client of ours has asked us to install a 65" LED TV several feet from his pool. He wants it to be flush with the pool decking, have it pop up, and swivel 180 degrees. We don't get much rain here but when we do, it floods. Can anyone recommend a starting point on this lift, any drainage tips, water sensors, etc? I was planning on a temp sensor and a water sensor at the minimum.
Well that link actually says indoor weather proof use but htis linkk says outdoor specifically.
http://panteltv.com/outdoorproducts.html
I have no idea where to look for an exterior grade automated mount. That sounds like a one off custom product that you may have to contract with a lift manufacturer you're already familar with to manufacturer. Might be cheaper to build a glass room around the pool.
Largest they have though is currently a 55".
I haven't seen a wet-condition tv lift, but back in my anti-terrorist security days we used to use custom made lifts using hydraulic actuators to raise and lower bullet resistant glass panels. If you use hydraulics, you can mount the electric pump in a remote dry location like the pool equipment room.
-John
The last outdoor system I did was a projector, and we just put it on a mount that could be easily removed to bring it inside when not in use. That's not real practical for a panel type set though.
