Standard Channels Documentation
I am looking for a document with a list of the standard module channels for use when writing my own Netlinx modules. For example, channel 9 is toggle power, channels 24 and 25 are for volume ramping, channel 252 is data initialized, etc. I am able to piece some parts together from AMX supplied modules but would much rather have a single document with everything in it.
The standard levels and commands would be great also.
I found a document once but it was extremely long. I am looking for basically a table with the number and associated function. Does this exist?
    In NetLinx Studio, go to the Help menu. Select the Standard NetLinx API Help option. This should list all of the devices.
  • AuserAuser Posts: 506
    wilw410 wrote: »
    Such a document may exist somewhere (a quick search of tech notes doesn't reveal one), but
    C:\program files\Common Files\AMXShare\AXIs\SNAPI.axi
    provides a definitive list of the standard channels and levels.
    You could dump this into Excel and do a data -> columns on it and then do a sort and filter to produce the table you're after.
