problem with the IR control of Dreambox 800HD
I've problem with the IR control of Dreambox 800HD. I've tryed to capture the IR but any command don't work.
Does anyone have the compleate IR File for 800HD??
  • Jorde_VJorde_V Posts: 393
    I don't have it in AMX format, I did make a Control4 driver for it. You should check that one out of if you can.
    The DB uses a hard to capture format so I had to take a few codes, compare them and then calculate the rest of the HEX codes.
