Conference between two different locations
Hello
I have been asked to establish a video conference between two different locations, after i made my research on the AMX web page, i found the DVX-2100HD is used for conferencing, i just want to ask if there is any other solutions made using other devices or if anyone already made a conference setup to help me on the design.
N.B: the client just sent me the following information:
1- Sony Bravia 40" LCD
2- Sony Bravia 55" LCD
so it seems that he has the TV screens only.
Best Regards
Rami
Best Regards
Rami
You're in over your head, by the way... you should probably look into hiring a professional.
As jweather said, if the conference locations are nearby and you can run cables between them, check an audio processor with Echo Canceling, and use a video matrix.
Check out Polycom Vortex products.
Thank you Prodigal, i will make the necessary research on the Polycom as you said, and please be noted that the locations are 200 miles away from each others, and there is no connection between the two locations but both are having DSL Connection (between 1 Mbs and 10 Mbs down), my question is how both locations will communicate to make the audio video conference run? is it through VPN with Static IPs or is there any other way, and what kind of protocols will be used (TCP. UDP....)
and one more thing, can i use this demo here, will it work for far locations:
http://www.amx.com/assets/videos/AMXMEETINGROOM.mp4
Thank you again for your support.
I have very successfully deployed Video Conferencing between sites with Polycom and using AMX as the control solution between sites.
EG Site 1 calls site 2 - Site 1: AMX connects through TCP/IP to site 2 and turns on monitors etc via Master to master treating remote NI Controller as a box of devices & gets Polycom site 1 codec to call/dial site 2 or vice versa and when the initiator of the call hangs up they can shutdown the far site as well. RMS Meeting Manager (http://www.amx.com/rms/ )would be of great benefit as you could then have the rooms automagically configure and be ready when you walk into the room through Scheduling
You would be best served to have dedicated / static IP's between sites with as big a pipe as you can get, >2Mb for SDVC or greater in the case of HDVC, I use the same pipe for both VC & control.
I think that you should get some good solid advice locally as the quality of the IP Links can vary between countries / states / towns.
Hope this is of some use
