NEC V461 RS232 CODES
I have managed to get this information from NEC regarding the RS232 commandas for the NEC V461. I hope this is of use. They have confirmed that for the volume must be sent as a value for each setting and to use increments/decrements of 5. I hope this helps.
http://www.necdisplay.com/SupportCenter/ManualsFinder/Manuals/?product=0256c842-e177-43d5-98b1-3c3db07cc177
For volume you can set any value between 0 and 100.
For volume increments/decrements you have to write function/procedure which will get current value from display, add/subtract step of your choice (1, 5 or else) and set new value to monitor.
Of course you need also separate function for checksum calculation.
Hi, its not a program, they are the codes from NEC .
Cheers
Julian
