Email auth with i!-EquipmentMonitor
Question,
I'm trying to setup a system to send out email alerts when specific devices go down. I am currently using the EquipmentMonitorOut.axi
I have seen on other posts that EquipmentMonitor doesn't support SSL secure connection with the smtp server. Does anyone know if it supports TLS secure connection?
  • Found a work around. Will be using a i!PCLink-Web to run a batch file on a remote machine using command line email software which supports TLS.
    If anyone else is interested, here is the command line email software I'm using:
    http://caspian.dotconf.net/menu/Software/SendEmail/
    [Supported Platforms: Linux, BSD, OS X, Windows 98, Windows NT, Windows 2000, & Windows XP]
    (works great if you want to send mail using gmail's smtp server)
  • truetrue Posts: 307
    No SSL support - and I really dread trying to port SSL to NetLinx ;)
    I have implemented SMTP AUTH in AMX's mailer but it is unencrypted (just base64-based auth, no SSL or TLS).
