Need more NV memory
How do I free up some NVmem on a duet master if I'm not using the duet side?
  • PhreaKPhreaK Posts: 966
    If you don't explicity specify non volatile/volatile/persistant any variable you declare will default to non volatile. Any variables that you're using that don't need to survive a reboot can be specified as non volatile:
    VOLATILE INTEGAR x
    If you've got a lot that is required to be non volatile downsize their types to only use the max number of bytes you need. For example, if you're storing boolean values, only use a char rather than an int etc.
  • PhreaK wrote: »
    VOLATILE INTEGAR x
    That helped but I'm still over:
    Volatile Free : 41777544/67108864 (largest free block in bytes/max physical)
    NonVolatile Free: -343856/523248 (program exceeded amount of NV memory)
    Disk Free : 24342528/31715328 (bytes of free space/max physical)
    Duet Memory Free : 0 (bytes)
    Partition 1 - <UNKNOWN>
    Partition 2 - <UNKNOWN>
    Suggestions?
  • Save the data to the compact flash and reload the data at each reboot?
    Kevin D.
    Check your modules, at least the ones you have access to the source code. Could be a lot of nonvolatile variables in those too.
    I explicitly set everything to volatile unless it absolutely needs to be otherwise ... and I have found very few do. In fact, I generally wind up with a small amount of persistent, but never leave anything non-volatile at all.
