Home AMX Technical Discussion
iRidiumHD problem
I have a code example draw in the TPDesign using bargraghs and when I convert the file using the iridium wizard and upload it to the iPad the bargraph doesn’t work.
I also tried the example in the website
http://amx.com/ui/file.asp?uiType=gElements&item=Sliding%20Popup%20Page%20Navigation
It doesn't work also.
The file is attached .
Thanks for any help that leads me in the right direction. Examples are very much appreciated.
iPod.AXW 207.3K
  • Is it working on a amx panel?
  • udiudi Posts: 107
    yes. it is working in the TPControl
  • so i think the problem is by iridium...
    but i have make a baragraph an convert it to a iridium project and it works fine.
  • MknMkn Posts: 11
    It is not problem with bargraph, multi-state bargraphs are used in this TP design. They will fix it with new updates.
  • udiudi Posts: 107
    so I can't use multi-state bargraphs. I need to use a regular bargraph?
  • ryanwwryanww Posts: 196
    Email their support address.. They are very quick to respond and will have an answer to you right away.
  • ryanww wrote: »
    Do you mean iridium? Quick? .....
    John
  • MknMkn Posts: 11
    Yes, they know about this problem and it will be fixed with 1.5.3.
    There is a workaround for temperary using this features - change the "Level Function" (into Programming tab) from "display only" to "active" for this multi-stage bargraph and it will work.
    Just ignore this level event in your programm.
